It is currently Sat Aug 09, 2025 4:21 am
PostPosted: Sun Aug 30, 2009 10:06 pm
I just used plywood cauls on the sides with tape on them, to keep the glue from sticking. Seemed to work fine.
PostPosted: Sun Aug 30, 2009 10:15 pm
Filippo, Robbie's video on making neck blanks shows two methods that are quick and easy.
PostPosted: Mon Aug 31, 2009 6:57 am
1/8 inch dowels in the corners, the dowel in the lower left corner is hard to see because it's still in.
PostPosted: Mon Aug 31, 2009 11:55 am
You must be using titebond, the slippin'est glue around.
Hide glue tacks real fast.
Of course if you are looking for perfect alignment, you'll want dowels of some sort.
PostPosted: Mon Aug 31, 2009 3:43 pm
somebody once showed me to do it sort of like a spanish heel, just run the whole stack through the tablesaw against the fence top to bottom with a very shallow cut in the excess, flip it and do the other side, then use a piece of sidescrap in each slot to keep things stable. I've never actually done it but it seemed to work for him...
PostPosted: Mon Aug 31, 2009 10:19 pm
First name: george
Last Name: wilson
City: barhamsville
State: virginia
Zip/Postal Code: 23011
Country: united states of america
You could just glue the blocks on one at a time. I never had a problem with them sliding.
